Old 10-31-2011, 02:26 PM   #2
The Radium King
The Radium King's Avatar
do you need the sensor to tell you how much pad you have left? if not, then you can fool the car into thinking the sensor is there ... cut the wires and twist them together (the sensor works by sending a signal through them - all good the signal gets through - bad pad and the sensor gets abraded and no signal shall pass).
