Old 10-28-2011, 06:58 PM   #1
blue2000s
Porscheectomy
You've not seen this swap for the same reason there are no GT3 swaps, it's not a drop-in like the M96/M97 engine. The mounting of the GT and turbo engines is different and requires fabrication. The intake/exhaust system is not compatible with the Boxster and the DME needs to be replaced, not reflashed. The guy doing to Subaru swap probably has an easier task than the turbo would be.
