Old 10-27-2011, 02:34 PM   #1
nprboxster
Originally Posted by healthservices View Post
I've read that the blend door on some models fall apart causing lack of heat. Not sure if this applies to you. Do you have any loose foam bits in the a ducts?
yes constant foam pcs coming out of vents. so whats it mean for my heater?less heat cause of foam missing/chunking? what do i do?
nprboxster is offline   Reply With Quote
