Old 09-15-2005, 07:32 PM   #7
MNBoxster
Hi,
1st Post here, happy to join the Forum. The best way to store any car for the winter is to do the following:
1. Change the oil just prior to storage. Oil absorbes moisture (a natural byproduct of combustion) and if old oil is left in the motor, moisture will evaporate out of the oil and condense on the engine internals causing corrosion. Also, oil becomes acidic with use and should be changed for this reason also. Change oil, start engine and run just long enough for the oil to circulate, then shut off for the season to prevent a buildup of moisture. If planning to change the tranny fluid in the coming season, it's also a good idea to do this now for basically the same reason.
2. Loosen the spark plugs and shoot either fogger oil (aerosol - NOT WD-40!) or a squirt of motor oil from a can into the sparkplug holes - about 1 tsp. This will prevent the rings from corroding and seizing to the cylinder walls over the winter. Upon initial startup in spring, oil will burn off in the 1st few minutes. I have seen piston rings seize to the Cylinder walls and tear-up on initial start-up requiring a rebuild to correct it, so I always follow this step.
3. Increase tire pressures to 50PSI. This will prevent flatspotting and leaks. The tire pressure will drop with ambient temp. Some will say to put the car on blocks, but with modern independent suspension, it's not good to leave it 'unsprung' for long periods. If you want to get really anal, fill the tires with Nitrogen. This is a Dry Gas and will prevent Dry Rot. Nitrogen can be obtained from any welding supply.
4. Store desiccants in the car. These can be purchased and laid on the floor front/back. This prevents mildew from growing and keeps leather from deteriorating due to accumulated moisture. Also, add an open Box of Baking Soda to absorb any odors which may accumulate. The 'Car Cacoons' currently being sold are very good for long term storage and use only a couple bucks electricity the entire season, also reduces door dings and the like. Absent this, use a quality car Cover.
5. Wash the car - don't allow pollution, Tree Sap etc. to work on the paint through the winter.
6. Remove battery from the car and put on a maintainer, preferably inside where it's warm. Be sure to allow plenty of ventilation to prevent Hydrogen Gas buildup.
7. Place the car on a sheet of Vinyl laid out on the garage floor. Make sure the vinyl extends 2 feet from any edge of the car. Garage floors seep moisture through the winter which can condense on the underside of the car, suspension, etc. causing corrosion.
8. Fill Gas Tank with Fresh, Premium fuel. A partial tank will corrode from moist air. Plus, it'll probably be cheaper than filling it next season. Use a stabilizer if you choose, but with Premium Gas, it's usually not necessary. If using a stabilizer, only add it when refueling so it thoroughly mixes with the gas, then run the car home so that the stabilzer can also work it's way through the entire fuel system.
9 Check Anti-freeze to be sure sufficient for temps anticipated - not relevent to an A/C Flat 6. Also, add a cup or so of denatured alcohol to the Windshield Washer Reservoir and run to circulate it - this insures that the water in the system does not freeze and ruin the pump.
10. Leave the car out of gear and with the Handbrake Off. If your garage is not level, or you worry about the car being 'rolled', place a brick under the front tire to prevent the car from rolling. Emergency Brake system and Calipers have been known to seize over a season of non-use. If they are engaged, it can be very difficult to dis-engage them (you may need to disassemble the caliper or mechanism to free it). On the other hand, if they are dis-engaged and seize, the hydraulic pressure and/or mechanical advantage of a cable/lever system is often enough to loosen them up again.
11. It may also help to place a couple of Mouse Traps strategically under the car, such as where the exhaust outlet(s), Frame openings, etc. are located. This can prevent something from Moving In to your car over the season. Mice will eat Plastic, Leather and Rubber, in addition to making a mess in general.
I live in Mpls./St. Paul - similar winter conditions. This is how I store each of my cars - Boxster, Lotus Esprit, 240Z, Formula Vee. Hope this helps...
Happy Motoring!... Jim'99
