Old 10-25-2011, 11:06 AM   #13
ABQautoxer
Send a message via AIM to ABQautoxer
That white connector should plug into the factory harness on the car. then you solder those leads onto the leads on your Sony stereo harness. Its a different harness if you have Nav from the factory...and it might be different if you didn't have door speakers. Use their configurator to help you out.
ABQautoxer is offline   Reply With Quote
