Newbie here and I know exactly what you are talking about.
Here is a quickie to see if one of your problems is your lower control arm ball joint.
you'll need a can of WD40 or penetrating oil in a can with a straw tip and a ice pick.
Go to your lower ball joint and puncture the boot with the ice pick, and
insert the straw from the wd40 in the hole, and give it a good squirt.
Watch your eyes as it may squirt back at you if you put in too much.
Take a test drive. If it is gone or changed drastically, think about replacing the lower arms.
If you have a clunking, clicking noise, another source of noise is the sway bar end links. Disconnect them from the sway bar and see if the noise goes away.
Good luck.
