Old 10-19-2011, 05:31 PM   #2
nprboxster
Originally Posted by fullthrottle52 View Post
I am not trying to be rude bu I don't understand why people here don't listen to what is being told to them. You need to have your engine smoke tested and look for any vacuum leaks. If nothing is found then REPLACE the MAF and reset the codes.
I chased the same problem for 2 months. Found a common air leak in the Oil filler tube. That did not fix the problem with 1128 and 1130 so replace the MAF and have not had a CEL for 3 months now. Running better than ever.
actually was rude. some folks need to read the question. my latest just asked if it was normal for the light to go off and on and then off a few days after cleaning. never went off prior to cleaning w/o resetting code.
nprboxster is offline   Reply With Quote
