Old 10-18-2011, 12:58 PM   #2
BYprodriver
BYprodriver's Avatar
Originally Posted by jaykay View Post
Yes exactly....I will investigate the vario cam function. I trust this can be done without a dyno?
Yeah, try your butt dyno 1st, with car in 2nd gear @ 1,500 rpm floor it, VarioCam kicks in between 2200-2500 rpm & revs really take off @ 4000rpm. If your not feeling it then remove cover behind the seats & with trans in neutral rev engine from idle slowly thru 2000-2700rpm & you should hear VarioCam change over if it's working.
