A faulty AOS (air/oil separator) can cause both oil on top of the engine end also the build up of oil in the intake. Check the AOS for splits or an easier quick check is to try and remove the oil filler cap with the engine idling - if the cap is difficult to remove (ie vacuum) then there is a good chance the AOS is faulty.
If you are using the car on the track, Porsche make a "competition" AOS which is probably what you should use.
2001 MV Agusta F4.
