Old 10-17-2011, 07:51 AM   #23
bar10dah
bar10dah's Avatar
Originally Posted by jakekit View Post
Mine wasn't that tight when I first installed it, but I did have to pull down quite a bit to close the gap. With that said, if your top is wrinkle free then you definitely got a tighter install on yours than I did on mine and that would explain how tight it is. Congrats on the job completed!
Also, your local installer is way cheaper than mine. Mine wanted 1500 bucks parts and labor. Ridiculous.
Good point on the eyelets, I think that is a common occurrence. I had to drill mine out slightly as well.
No quite wrinkle free. I have a few ripples on both sides right above the windows. I'll wait it out to see if they go away on their own when the top is done stretching. I can see them when walking up to the car in the sunlight. Couldn't see them last night standing right over them with a flashlight.
Mine wanted $1625 parts and labor. But if I were to bring him a top, he'd install for $500. And as I was watching him type in the numbers into his calculator, he was only charging $400 to install if I were to get the top through him. Guess he needed to pad his profit if he wasn't going to make anything off parts.
bar10dah is offline   Reply With Quote
