Originally Posted by deliriousga
If neither of those work, it may be the window regulator or the window motor.
The window regulator does not effect the manual operation of rolling down the window. The window regulator
only operates the auto roll down 1 inch. My bet is the window motor, fuse, or relay. If not then you might have a combination of problems, also known as a $$$ pit
