Old 10-13-2011, 06:11 AM   #2
pk2
The key is the "clock spring" which rides behind the wheel. It needs to have the proper # of electrical leads to and from it. It's purposes is to allow the wheel and it's wiring to turn without twisting up the wiring coming from the steering column.
Getting a Tip. set up sounds like a good Idea. Otherwise if your handy you could ,od your wheel with switches and just find a clock-spring.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
