Originally Posted by gauoogauoogauoo
Hi. I am a newbie here. Have a 97 boxster. The passenger side window would roll down and go down an inch when the door is opened. However, the driver side doesn't roll down neither does it go down an inch when the door is opened. Could this be a fuse just causing the driver side windor to be malfunctioning?
Can you guys give me some advice on this?
Thanks in advance.
When you try to put the window down can you hear the motor run? If you can then your problem is from the relay, the windown may have slipped off, if u dont hear anything then chances are you need a new window motor.
