Old 10-09-2011, 08:11 AM   #11
JFP in PA
Originally Posted by Bellster View Post
Drainage lines all clear so what now will it be the heater core leaking if so where do I look now to find leak ?? No leakages for tanks all holding coolant !!
Fastest way is to pressure test the system while opening up the cowl area from the front trunk. The pressure test will confirm the cooling system is leaking with in moments, looking down into the compartment containing the heater core should visually confirm that is where the leak is. From there it is a matter of swapping out parts and purging the air from the cooling system, it is also a good time to do a complete cooling system dump and refill..........
