Originally Posted by Burg Boxster
yes, there is supposed to be a manual release on the '01. It's a steel cable ~ 2mm with a finger loop on the end and looks like this:
For convenience purposes, a lot of people will re-route the cable behind the front bumper tow plug.
good luck
Thanks Burg Boxster, looks like the other end of my steel cable has dropped off the latch... time to investigate further and see where it should fit... I was rushing to put back the bumper the last time.
I presume the loop that you showed is "normally" behind the wheel liner ? It looks like where my cable was headed.
