Old 10-07-2011, 07:42 AM   #4
JFP in PA
Flavor is most likely correct; unless you can confirm that the wetness contains coolant (it has a pronounced smell and oily feel), your AC system drains are plugged and condensation is dripping inside the car rather than underneath it.
If it does turn out to be coolant, it will be your heater core leaking, the coolant tank cannot leak into the passenger compartment. Fortunately, the Boxster has to be one of the easiest heater cores to swap out, so even that would not be a major issue.
