Originally Posted by Burg Boxster
2 adjustments available...
- 2 black (could be faded to white) rubber stops, one on either side of front of hood can be screwed in/out (rear trunk has them as well)
- female recepticale for latch can be adjusted up/down. Remove black plastic trim piece under hood at front bumper and you'll see latch receptor there. Loosen 10mm nuts and slide up or down as needed and re-tighten to secure. Make sure hood, when closed, will be slightly below front bumper lip or you'll get a whistling sound. Of course, after you adjust here you'll need to readjust black hood stops above..
Good luck
I don't seem to have the black stops on the hood. I have bolt heads on either side of the latch. I am not sure where they would contact if they were there; there is only the plastic cover trim piece below. It looks like the front edge of the hood is below the bumper lip already so I will have to look at another source for the whistling noise I am getting
