Also, the new mount has four mounting points on the engine side, as opposed to the earlier models which only have three. You can only take advantage of this fourth mounting point if you have the newer style oil pump housing cover on the engine. If you don't I wouldn't worry about it as I don't think it is worth the trouble and expense to change it.
'99 black 986
