Originally Posted by Burg Boxster
2 adjustments available...
- 2 black (could be faded to white) rubber stops, one on either side of front of hood can be screwed in/out (rear trunk has them as well)
- female recepticale for latch can be adjusted up/down. Remove black plastic trim piece under hood at front bumper and you'll see latch receptor there. Loosen 10mm nuts and slide up or down as needed and re-tighten to secure. Make sure hood, when closed, will be slightly below front bumper lip or you'll get a whistling sound. Of course, after you adjust here you'll need to readjust black hood stops above..
Good luck
Thanks much appreciated. There is good chance you have found the source of a whistling sound I have as well!
