Thread: Cheap mufflers
Old 10-05-2011, 09:41 AM   #16
Steve Tinker
Steve Tinker's Avatar
Steve, would the lack of heat dissapation hurt anything?
I cannot imagine so.
My experience is that the (normal) heat soak out of the steel actually goes out of the tail pipe - this is the main reason we use ceramic coating or wrap on motorcycle exhausts as it helps with under fairing temps.
I was just imagining that quite a lot of this unwanted noise is eminating through the steel wall of each chamber & wrappng it may reduce the drone.
It wouldn't be an expensive experiment......
2001 MV Agusta F4.
