Old 10-04-2011, 04:27 PM   #17
keithl
Originally Posted by peterbrown77 View Post
Did you have to replace the transmission or just the cable?
So I recieved the cable today. I removed the transmission, i have the updated version, and tested it with the new cable. The cable seems to spin correctly in the transmission but the center wheel (where the large 19mm bolt goes) of the transmission never turns. Is that what happens when the transmission breaks? I would think the transmission would have jammed thus breaking the cable and then wouldn't turn at all.
Update:
Ok, i took the transmission apart, and it seems o be working apparently it moves so slow you can barley see it move.
keithl is offline   Reply With Quote
