reply sent. In the interest of others, here is my reply:
How to install them:
first you have to remove the cluster:
Instrument Cluster
This will allow you to replace the front glass meaning you can attach mine with the silver rings, and that's totally easy, the more trickier part is to replace the faces as you need to first move the needles out of the way: the actual process of replacing the face is described here:
Speed Yellow Gauge Faceplate - Articles
- scroll down to the middle of the article
But as an advise: You must be super careful and smooth when you take the needles off as there is a chance to dislocate the fragile cogs inside the motors which drive the needles.
If you have doubts that you can perform any of the steps described above, then better don't do it
