			A couple of thoughts:
 As a former '99' MY owner I'd suggest the ROW 030 suspension--very cost effective.
 Regarding tires and assuming you're on stock 7"/8.5" 17" rims, think about these as alternatives to R comps if you aren't trailing your car:
 Nitto NT05
 Kumho XS
 Hankook RS-3
 All can be driven on the street, have way better traction than regular street tires, good for minimum 10-12 track days depending on how bad you beat them up--and best--not real expensive; I think the Hankooks are under $500 for the set--dirt cheap.
 A second set of wheels is the way to go, BTW; used boxster style wheels are pretty cheap ($500?).
 Last I didn't hear anything about brakes; if you're doing DE's think about a pad for tracking; Pagid makes a few that will work if you use OEM pads on the street.
 Same thing about fluid; I like Motul 600
				__________________2013 Boxster S
 2006 Boxster--sold
 1999 Boxster--sold
