Old 09-30-2011, 02:44 PM   #17
Ghostrider 310
Ex Esso kid
Originally Posted by Aron in Toronto View Post
Ghostrider,
You are correct that the 2.5s have a double row bearing, however this is a "serviceable" bearing in that it can be removed w/o splitting the case. Porsche returned to a double row bearing in 2006, but this later style cannot be replaced w/o opening the case so yours should replaceable assuming this is related to the noises you heard.
Aron, I'm wondering if it might not be the timing chain, tensioner or the bearing. I was lucky, it failed at idle while parking. For some reason without thinking I decided to restart it as I wasn't really sure what happened. The engine, respective to the way a normal rev would sound was smooth, tight and as regular other than a jingle/rattle, I immediately shut it down and that's it's current state. I have to chuckle, I used the heavier lubricants, changed the oil and filter with ludicrous frequency and even put magnets on the filter case... It was used and although I drove it with respect who knows how it started life.
Tony
