Old 09-30-2011, 12:12 PM   #3
Dale_K
According to some Porsche technical information I found, the only signal the car monitors when it checks the air injection system comes from the O2 sensors. A low signal level on the O2 sensors means oxygen is present so the car's computer expects to see the O2 sensor levels fall when it activates the air pump. This is monitored once per key cycle. Send me a PM if you need the actual tech document.
Dale_K is offline   Reply With Quote
