Old 09-29-2011, 05:35 PM   #10
Highlow
I had the same issue with the windows. I figured that there was something wrong with the microswitch where the latch was, so I ignored/dealt with it.
At the same time, I was having this problem where the red convertible top light on the dash would light up every time I went over a bump.
I knew there was a connection issue somewhere in the convertible system so my first thought was to make sure the relay was ok. It turns out that it was a little bit loose and that it was causing both of the above problems!
Short story shorter, make sure your relay is in there nice and tight.
BTW, I just bent my pin 18 so that it was flat (no tape). It would be easy to straighten out if needed.
Highlow is offline   Reply With Quote
