Originally Posted by jsceash
I believe the mod you are talking about will put you into a street prepared class. The limited slip differential is not an allowed replacement in stock. Sway bars are allowed to be changed if they are stock on a car of the same year or older and the part or vehicle don't have to be modified to install it.
Haha no no no. According to SCCA Solo rules, front sway bars may be removed or replaced without limit as long as it has the same mounting point, but rear sway bar may not be touched. And STR (Street Touring Roadster), and all ST classes for that matter, allow for the use of ANY differential. :P
Yay for spending way to much time with a rule book XD
