Old 09-26-2011, 09:32 AM   #10
AtlantaBoxster
Originally Posted by DenverSteve View Post
Look at and rub your tires. You should be able to verify the cupping or other uneven tire-wear situation. Since you've been advised twice that it's a tire issue, I would start there. Front end noises, on a rear-wheel-drive vehicle can only be the few already suggested issues. You'll have to eliminate one at a time. The high-performance tire shop you took it to should know what they're talking about.
Agreed they should know. When I took the tires off, they were like new having only ~4K miles on them. I saw nothing of the purported cupping he was talking about.
I forgot to mention that I removed the right front and back tire one at a time and replaced with the toy tire and the issue was still present. I will do the same (once the battery is charged back up) with the left and see if I still hear the problem.
My thinking is that if the problem still persists at the same level with the toy tire on, there is more likelyhood that it is not a tire issue.
AtlantaBoxster is offline   Reply With Quote
