Old 09-25-2011, 03:48 PM   #3
ppbon
ppbon's Avatar
You will need to ...
Originally Posted by THTABE View Post
The bolts for the break line bracket on the front struts sheared off on both sides of my front end. I need thoughts on how to deal with the two sheared bolts.
Thanks!
Tarry
... remove the sheared bolts by drilling out the center of the bolt and then using either larger and larger left-handed drill bits or a bolt extractor.
You should not drive around with the hard brake lines hanging loose and vibrating (without support) as they can crack and lose all the brake fluid.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
