You could do the MAf (mass air flow) not MAP, we don't have map sensors, and all four 02s and you should be fine. But it is $$ if you could get somebody to narrow it down it would be best. If it turns out to be on of the 02s I personally would change all four in stead of just the one. If you have to do the the 02s you can do it your self if you feel for much less than Porsche. I think the buildable sensors from napa are about 90 dollars each. Other wise you could order from birtsmith porsche or sunset in cali. Both have great prices.
Good Luck
