Old 09-10-2005, 01:37 PM   #1
Porschev
Question White Smoke From the Engine then starts
HI guys
I experienced this for first time :
Taken from 986faq.com
"Diagnostic: White smoke comes from tailpipe when the engine is started.
Cause: Oil residue under the pistons heads.
Details: The Boxster engine uses a flat six cylinder design. Because of this construction, oil residue remains under the piston heads and burns off at every start up. This can produce a white puff of smoke. It should only lasts a few seconds. This is normal, and no correction is necessary."
Question may be i need to take some oil off, i changed the oil recently and maybe put more than nessesary?
Thank you all
Porschev is offline   Reply With Quote
