If you delete all of the cats, the vehicle will no longer be OBDII compliant, and it will subsequently fail emissions (not to mention CEL's). In addition, from a performance standpoint, it's been my experience (with the 3.2 engine) that going catless will result in a measurable loss of low end and mid range torque.
Running RoW spec DME will not read from the 2nd o2 sensors,so you can remove the 2nd set of cats without a CEL light.
You should still pass smog....I was going to do this to my 01' S cause the 2ndary air injection used on cold starts went out and I wasn't gonna pay $1k to replace it when it really does nothing.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
