Old 09-09-2005, 12:34 PM   #2
Joji
Hi,
I got it working. I am able to fit it on the right or left side behind the headrest. I don't have that compartment back there. It is just carpeting and a net. The sub is ok., It does the job. It has low end. Not extremly defined but not bad either.
Now that I tested it. I have two questions.
I need to run the line to the + side of the battery. How do I get from under the passenger or drivers side into the front trunk to the battery?
Next the porsche dealer said I can hook up the Blue iginition wire to the back of the fuse box. I was able to get the cover, carepeting and unscrew the 4 srews. But how do I get hte hole fuse box to come off. I need to access behind it so I can merge my wires.
If anyone has pictures, that would really help
thanks
Joji is offline   Reply With Quote
