Thread: Rain Damage
Old 09-08-2011, 05:28 PM   #3
jrdiesel01
jrdiesel01's Avatar
Drain hose plugged
This happened to my box on driver side Check drain hose between ragtop and rear quarter (right next to door). You can only see the drain hole from there, remove any obvious debris gathered or stock I'm there. Next, get an air compressor hose and blow air into hole to clean hose. This should solve your problem. Recommend doing this to both sides routinely.
http://www.cardomain.com/ride/3301906
jrdiesel01 is offline   Reply With Quote
