Originally Posted by DenverSteve
Does the wheel/tire height change the widest possible width? I know this is well-discussed and known information to some. For some of us .... you know, drivers....  this is not well known. I have factory 18" wheels with 55mm offset. If you go wider, do you need to increase or decrease offset?
In order to advise you correctly, more information is needed . What size wheels and tires are you currently running ? And, do you plan to change over to 19 's ?
