Old 09-05-2011, 01:45 PM   #1
stateofidleness
Part numbers request
Can someone check some part numbers for me and also, do you know of an online retailer where I can add items by part number?
I cleaned out my radiators this weekend and found some maintenance items that need to be replaced:
1. the plastic/rubber U-shaped guard (underneath the front trunk lever) up front. The rubber "seal" part of this is deteriorated and was crumbling.
2. the little plastic "screw clips" that hold that guard down (there's 4 of them)
3. the left and right rubber air guards just in front of the front tires on each side (mine are broken)
4. the rubber air deflector things directly underneath the engine on each side
Thanks guys.
stateofidleness is offline   Reply With Quote
