Thread: CLUTCH Question
Old 09-02-2011, 09:56 PM   #5
Spinnaker
Spinnaker's Avatar
Sounds like the clutch is toast. With 96K on it, that is more than most clutches will last. Make sure that they check the IMS while they are in there. If you can afford it, now would be a good time to update to the LN bearing, since everything will be apart and it will be easy to do it.
