Old 08-31-2011, 07:28 PM   #19
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
I tell you what guys, I'm about 99.9% sure I did the usual when I pulled over and had the brake up and handle unlatched when I tried to move the top before and after removing my lunch bag from under the clamshell...but now you've got me doubting, lol. At the same time, I know that all activity stopped with the brake handle up because that's what happened when things went pop. I tried pressing the switch in either direction after the pop and nothing happened. I'm going to try tomorrow evening to work the top and see if the clamshell moves. The brake is already up so the latch is the only thing I'll have to do. Watch it make a liar out of me.
If not, then could the fuse have blown just as ironic timing or as a result of the malfunction?
-O/D
IMSR + RMS
Robbins glass window top
