Old 08-28-2011, 03:46 PM   #2
JFP in PA
First, do not pressurize the motive unit beyond 15 PSIG; higher pressure is not required, but can lead to problems. Second, the clutch should be held to the floor while bleeding it, then manually pull the pedal up; you should be fine at that point.
