Old 08-28-2011, 01:54 PM   #1
Porsche Enthusiast
When I actuated bank 1 nothing happened to the engine while running, I can hear a slight click I think when the engine isn't running.
When I clicked Bank 2 start while running, she sputtered hard and coughed out.
Another odd occurance, when I turn on AC she runs better and the CEL goes solid. If I turn it off CEL stays solid for about 2 minutes then starts fladhing again. Is it the sensor not adjusting, and the AC kicks up idle closer to the existing default no sensor running range?
I found what pins go where (25 on Connection) and how tho test the connection and the sensor. Yup climbing the learning curve, thanks for helping me narrow it down. If you had to guess statistically, what direction should I test first? start at DME and move towards sensor or start at sensor going back to DME? Just wanting to rule out most likely candidate issue first.
Porsche Enthusiast is offline   Reply With Quote
