Old 08-28-2011, 02:50 PM   #1
The Radium King
The Radium King's Avatar
clutch bleed question
hi all. just bled my brakes and clutch (motive power bleeder at 25 psi, open bleed valves 1/4 turn, run until no bubbles, torque to 7.5'#). now my clutch will not return when depressed. i'd read in a tutorial (boxster wiki) that this may happen, and to drive about gently to get it to start returning; make sense? also note that, when bleeding, i did not depress the clutch pedal prior as per bentley et al; i was under the impression that this was just to ensure that the master cylinder was completely evacuated (not required in my case) and should not be related to this issue ...
