Depending on the size of the tire that you are using, the difference in "cushion" (i.e. sidewall thickness) between 18's and 19's can be negligible . Also, depending on the tire's composition, there can be a noticeable difference in ride quality - that isn't necessarily based on size alone . For example, my oem 18's fitted with Pirelli P-Zero Corsas were enough to knock your dental work out as compared to the current 19's that I am running . Lastly, there is no way an 11 inch wheel will fit on a 986 boxster .
