You are getting a bucketload of random error codes that point to:
Damaged harness or bad connections, damaged DME, bad ground connection at battery or DME. When the trans came out did something get pinched?
Your DME is pretty aggravated right now and not giving much meaningful info to help eliminate all the possibilities.
