I was lucky enough to score a set from my local dealer when the new 911 showing was going on. I got them for $900.00 because they had been sitting around for awhile. I did wire them in so that the low beams swivel up when the high beams are on. These babys really light up the road, in fact if the road signs are fairly new the reflection is really bright. I do recommend installing the wiring kit that comes with them, it is really easy. I did just splice in the wire though since I did not have the tool to remove the pin. It is not rocket science, just geting power to the control is all.
It may be worth checking with dealers to see if they have a set around because I think most new ones are ordered with them and the upgrade urgency is going out so they may be motivated to move their old inventory.
Roger
