Yes, Mike, the car's 100% stock (if you exclude my having to replace the top), and the only modification has been an IMS retrofit and RMS replacement. I listed all work done to date a few posts earlier in this thread.
How should I go about tackling the harness issue? Just go find it and make sure it's all snug and plugged or does it require full replacement? Any chance this loose connection might also be causing the flickering/dimming of all of my car's lights (interior & exterior) and cutting out of stereo sound while running? The ignition switch has been replaced with no change in the symptoms.
-O/D
IMSR + RMS
Robbins glass window top
