Old 08-20-2011, 01:44 AM   #10
san rensho
Originally Posted by Flavor 987S
Husker, really, the water pump is a weak spot? Are there any tell tale signs prior to the event?
Play in the water pump pulley is a sign the pump is going out. Relaese the tension on the auxiliary belt and then chaeck the pulley for wobble. I replaced the belt and the pump failed promptly after that.
Its important to catch the pump before it fails because when it does, the plastic impeller tends to grenade, which can send little bits of plastic into the tiny coollant passages in the head which can cause blockages and lead to cracked heads or blown head gaskets.
Many people treat the pump as a wear item and replace it periodically, 30-50k miles to avoid problems.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
