window issue
I have odd problem with my passenger door lock/window. For one when I lift the the outside/inside handle the window does not drop the 10mm its suppose to. The other problem has to do when I manually unlock the car with key on the driver's side door. If I do not put the key in the ignition soon after unlocking the alarm sound goes off making it think the car is being broken into .. Go any suggestions? I know that the window not dropping can be either the inside/outside handle microswitch OEM-99661312300 ...but what is your take on the alarm sounding when I unlock. What microswitch is in control of the lock to tell the alarm that it was unlocked by a key.
