Remove the fuse....
...one at a time to isolate which circuit is "closed" and drawing too much current.
BTW, I don't know if the current you reported is "normal" or not. My suggestion is based on the assumption that you are drawing too much current when the car is "off."
Good luck.
P.S. Start with the easy ones: the lights under/inside the trunks.
