Insite, would you know where terminal VS.24 is located? That's the tie in for the reed switch, tank vent valve and the fresh air valve in the Bentley wire diagram. We think that's the location where the problem might be. But i have no idea where VS.24 is. You had mentioned that it could be on the climatronic. Would they tie in at the location in the trunk on the diagram you supplied? Not sure if you know but any help would be greatly appreciated.
Thanks!
