Old 09-05-2005, 10:00 PM   #6
TO2IMAGE
i copped my litronics for 600.00 a while back back then there was a theft problem going on because so easy to take so i recommend when mounting these you also put some sort of strap on the inside to lock them in.of course that wont prevent them from triing to take them but they will be un successful. i beleive i used a 5mm socket insted of the tool that comes with the car.very simple install just open hood take out plugs on left and right side behind carpet put in ssocket tool and turn counterclock i beleive this unlocks your lights pull them out then just slide replacements in they will plug right up into your factory socket. you will only need to get the wire kit if you want auto level for high beam ibeleive i didnt even use that but the lights are cool blue very nice.
TO2IMAGE is offline   Reply With Quote
